ONEX #54 Web Site
ONEX
W09
Rivet/bolt LH subframe
Made and installed new W10-03L outboard rear spar attach angle.
Used two coats of "Plasti-Dip" on the electrical contact holes to help insulate them.
Enlarged the fwd 1/4" rib guide holes to 5/16" to use 5/16" OD tubing for a lighting wire conduit.
Riveted and bolted the ribs to the main and aft spar. Torqued bolts to spec and applied "torque seal" to all the nuts.
Still need to enlarge paddle holes (rev dtd 2-29-12) prior to installing the skin.
Plasti-Dip coating on electrical hole
LH outbd subframe riveted
ONEX Home
1326
Basic Information
Certification
Finish and paint
Flight testing
Fuel
Systems
Trips
458
